ArcGIS Data Store 10.4.1 configuration error
5319
06-27-2016 02:52 AM
nita14
Occasional Contributor III
Hi All,
While configuring ArcGIS Data Store, I receive the following error:
<Msg time="2016-06-27T11:27:52,0" type="SEVERE" code="110506" source="Data Store" process="16468" thread="24" methodName="" machine="C3ISR02" user="" elapsed="">Attempt to configure data store failed. com.esri.arcgis.datastore.common.DataStoreException: java.lang.Exception: Machine 'https://xxxxxxxxxxx/arcgis/datastoreadmin/' returned an error. 'Invalid Token.'</Msg>
My site configuration is as below:
ArcGIS Server 10.4.1 with https only communication enabled. I use default ArcGIS for Server self-signed certiifcate
No changes to security settings were made. I set up Web Adaptor as well/
Did anybody undergo the same issue?
Kind regards,
Adam
nita14
Issue resolved. Firstly, Portal for ArcGIS and Web Adaptor should be configured accordingly
nita14
