Hello,
I need to do a full backup of an AGE 10.5 using the WebGIS DR tool.
The final aim is restoring it on a different machine as described in the guide Migrate to a new machine in ArcGIS Enterprise using the WebGIS DR tool
My server OS is Windows 2008 R2 64bit.
I am following Create an ArcGIS Enterprise backup—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise.
I have configured my webgis.properties file (called "webgisdir_BAK.properies"), and then I launch from the CMD the command:
webgisdr --export --file "C:\Program Files\ArcGIS\Portal\tools\webgisdir\webgisdir_BAK.properies"
Unfortunately, I receive the following error:
Failed to generate the ArcGIS Server token from the portal https://svksi058a.globalnt.it:7443/arcgis/sharing.
Failed to get the configuration of the web GIS.
Stopping the webgisdr utility
I attach the encrypted "webgisdir_BAK.properies" and the "webgisdr.log".
I also tried to set the ArcGIS Server to HTTPS Only and have my Web Adaptor allowing administrative access as suggested in Portal Backup with webgisdr: Server is not started, but still I had no luck.
I also opened a case to Esri meanwhile but as this is an important operation, I wanted to post my problem here to see if I had more chances to solve it.
Thanks in advance.
