Kelly Boyd-
Can you please share how you manually made the change?
Here is our attempt at a work around but it did not work as we wanted:
- Manually altered the files in the config store on the AGS Server that link the user with the role. Now the user names get saved as "AD\\username".
- Then took the AD off the username in the config file and it does show up without the AD\ in Manager, but it has no effect in how you log in. (i.e. you need to add AD if you are to get access to the correct folders).
Legacy users are still able to log into our secure services without a prefix to their username. All new users need the prefix.
