Hi Abdelwajid,
Trying to install and enable ArcGIS Server 10 (which is no longer supported) on Windows 10 OS isn't really practical. The software was not designed and not meant to work with this OS release. And it's likely that the OS has different and/or upgraded internal components that ArcGIS Server 10 won't understand.
I recommend you get a more recent release of ArcGIS Server to use.
Hope this helps,
