ArcGIS server does not recognize the host name when I change the computer name
2436
12-09-2012 07:48 PM
Reza_MahmudunNaym
New Contributor III
Hi
I installed ArcGIS 10.1 for Server. After that I needed to change the host name. But after changing when
I tried to join a site then a error message shows with the previous name(cannot find the old name local server)
Then I uninstall the server and re-install it. Still it says cannot find the local server with the old name. I dont know
where its getting the old name.
Can someone tell me what to do...
Thanks
Naym
BubbaHey
Occasional Contributor III
What's the exact error message? What happens if, instead of join a site you create a site?
Add Both Physical machine's   IP address and Host name in the 'hosts' file which is located under the following location.
C:\Windows\System32\Drivers\etc. See if that helps. If still a problem, try installing SP1. SP1 fixes a lot of bugs.
MuryadiOey
New Contributor III
have you check your dns result by nslookup? what did you get?
