ARCGIS server installation in linux
1766
10-15-2016 01:43 AM
rubatala
New Contributor III
I need the whole steps especially the terminal command that I should use to install ARCGIS for server in LINUX
RedHat or Suse??
the steps in Esri not clear especially in the command.
rubatala
New Contributor III
Thank you, Dan, but the link is for server in Windows I need the basic command for run and install ARCGIS for server in Linux OS and  I checked from Esri but there is no clear steps for that.
can you provide me with clear step for the installation and give the right permission to run the AGS??
DanPatterson_Retired
No... hope this is the one
Welcome to the ArcGIS for Server (Linux) installation guide—Installation Guides (10.4.1) | ArcGIS fo...
people will need a reference point within the installation to be able to help, so I am assuming that you are following the documentation in the help... if not, then you need to provide that documentation and where you are having trouble.
