ArcGIS Server StartUp Error
3762
02-09-2016 03:43 AM
EphraimMuya
New Contributor II
I need help debugging an ArcGIS Server (10.3.1) StartUp error that i keep getting.
service_error.log:
java.lang.NullPointerException
    at com.esri.arcgis.discovery.admin.plugins.LogServiceObserver.a(LogServiceObserver.java:55)
    at com.esri.arcgis.discovery.admin.plugins.LogServiceObserver.beforeStart(LogServiceObserver.java:49)
    at com.esri.arcgis.discovery.nodeagent.impl.ObserverManager.beforeStart(ObserverManager.java:146)
    at com.esri.arcgis.discovery.nodeagent.impl.NodeAgent.c(NodeAgent.java:246)
    at com.esri.arcgis.discovery.nodeagent.impl.NodeAgent.start(NodeAgent.java:138)
    at com.esri.arcgis.discovery.nodeagent.impl.Main.start(Main.java:56)
DanPatterson_Retired
Ephraim
Please redirect your question to a more appropriate location.  GeoNet help is about help on using GeoNet.  Your question is obviously more targeted.  Here is the community structure
GeoNet Community Structure
KenBuja
MVP Esteemed Contributor
It has been moved to ArcGIS for Server
