Jonathan Quinn
Can you stop and start one of the services and see if the service information re-populates?
Actually, the way we solved the problem for all the services was to restart the entire ArcGIS Server service.
Which Windows update installed?
I am going to contact one of the IT person of one of these three customers and hopefully I will ask about what was the Windows update and update this post.
Are all services missing their information, or only services with certain data sources?
All three customers have a new AGS install with only the sample Map Service provided by Esri and another one for test. This one is a Map Server showing data coming from either a SQL Express GDB or a FileGDB registered with the AGS. The thing I noticed in the rest page of these test map services is that all layers were missing in the list, and extent was all "None". So it seems the problem might be related to data registered with AGS rather than copied to the server directories during publication. Indeed, validating the registration (from ArcgIS Server Manager -> site -.> Data Store) was failing before restarting the ArcGIS Server instance.
I will hopefully give you more info about the Windows update this same afternoon.
