ArcGIS Web Adaptor (IIS) 10.8.1 Stability Patch
2254
6
12-20-2020 11:23 PM
StefanUseldinger
Occasional Contributor II
I just installed the ArcGIS Web Adaptor (IIS) 10.8.1 Stability Patch to fix BUG-000136092.
The machines are hosting two Web Adaptors each (/arcgis and /portal). In the "Installed Updates" section, the update is only shown for one Web Adaptor after the installation.
How can I guarantee that the patch has also been installed for the other Adaptor?
Tags (1)
2 Solutions
PanagiotisPapadopoulos
Hi, if run the Patch Finder you will see that the patch installed on the Portal's Web Adaptor
http://downloads.esri.com/Support/downloads/other_/PatchFinder.exe
According to the patch description I think this is the case
https://support.esri.com/en/download/7855
DavidHoy
There was a further clarification update to the Patch download page that explains why only one Web Adaptor appears to have been patched. https://support.esri.com/en/Products/Enterprise/arcgis-web-adaptor/arcgis-web-adaptor-iis/10-8-1#dow...
Important Note: A single installation of this ArcGIS Web Adaptor (IIS) 10.8.1 Stability Patch will update all ArcGIS Web Adaptors configured on a machine; no additional installation or configuration is needed for multiple web adaptors on a machine. You will observe some limitations with the tools used for finding and notifying of patches. The PatchFinder.exe is currently limited to only showing one web adaptor even though the patch has been applied to all web adaptors. The Patch Notification tool does not currently support showing patch notifications for the ArcGIS Web Adaptor.
StefanUseldinger
So is it installed for both Web Adaptors on the same machine? To me, it doesn't seem as if this would be the case...
No it is installed only for the Portal' s Web Adaptor (Instance portal, in my case).
There are 2 web adaptors configured, one foe the Portal component  and one for the GIS Server. The Patch according to the description is for the Portal component.
StefanUseldinger
Thanks for the clarification!
DavidHoy
MargaretBaker
New Contributor II
I hope that the Patch Notification tool is being fixed to find patches for Web Adaptor if it is installed on the machine in question
