I found out today that because the license server is on Citrix, our local desktops/laptops won't be able to borrow (in ArcGIS 10) any licenses because it cannot directly connect to the license server. (The Citrix farm is in another city) This is a big drawback for us as we have users that go out in the field where there is no cellphone/internet coverage.
We are in the process of doing the same thing with ArcGIS 10. We are putting it on a Citrix6 Farm on Server 2008 R2 servers.
To solve the printing issue, we have created a print server that is in the data center that is local to our Citrix farms. This allows the print jobs to off load the terminal servers quickly. When then have the print servers print directly to the local/network printers inthe various offices directly across the WAN. In our testing phase this is what yielded us the best results for printing.
Still, I was hoping there would be others with a Citrix 6 and ArcMap 10 environment that I could do more reading on so I can know how to optimize my Citrix installation to get the best performance for my environment.
I am not able to personally test this without access to a Citrix environment, but I double checked with a couple of sources that say you should be able to borrow a license from the license manager that is running in the Citrix environment as long as the client can connect to it. Maybe you could provide more details (error messages, connectivity issues, etc.)
Julie -
Is the poor performance on client side systems only? For example, if you can find a way to remote into the Citrix box (Win2k8) using RDP, do you find the performance remains slow? Also, running Task Manager on the Citrix box, how many ArcMap.exe's do you see running? ArcMap is a pretty hefty product it is quite easy to overwhelm a Citrix server with only a few clients.
