ArcSDE Workgroup will only work with SQL Server Express.
You can either use the SQL Server Express 2008 R2 provided along with the sde setup OR download/install any desired (supported) version of SQL Server Express from Microsoft's site and use it as well.
However, if you have to use SQL Server Standard edition (the SQL Server express has database size limits)......then you need an ArcSDE Enterprise license for that.
