Change ownership of SDE feature class
8863
04-09-2015 07:08 AM
LinkElmore
New Contributor III
Is it possible to change ownership, either in SQL Management Studio or ArcCatalog, of a feature class created by a non-sysadmin user, to the default (dbo) schema?
I am using SDE 10.3 and SQL 2008 R2.  Users authenticate via Operating System Auth (Windows Active Directory).
I have a number of users who need to be able to create new feature classes but our security policy permits only server admins to have sysadm rights on SQL, therefore any feature classes created by non-sysadmin are named and owned by that user, even if they are given dbo as their default schema in SQL.  The resulting feature class name is "[database].[domain].[user].[featureclass]" rather than the desired [database].DBO.[featureclass].  I would like to allow my users to create the feature class under their account and then use my sysadmin account to change ownership to DBO so as to be available to all enterprise users under the default schema.
I have tried simply editing the dbo.SDE_table_registry table in SQL to change the owner to DBO, but when I do, ArcCatalog no longer displays the feature class (under either name).  Clearly, this is not the only place where the owner is being stored in the SDE tables.
Does anybody know of a way to effect this ownership change, or a different workflow that would allow non-sysadmin role users to create new features as DBO?
VinceAngelo
Esri Esteemed Contributor
No, it is not possible.  Modifying the system tables directly will just corrupt your instance, and the tables themselves have triggers and linkages which would be corrupted.
The original feature class would need to be copied as the new user, then the original feature class deleted.  Versioned edits and archive history would be lost.
- V
VinceAngelo
- V
AlessandroValra
Occasional Contributor III
I think this is not really what an admin wants: having anybody who can create content being the owner of that object and the only who can actually manages it (e.g. Register As Versioned). This sounds really odd to me...
HollyZhang1
New Contributor III
I have this same question.
