I have a feature layer that uses our SQL Enterprise Geodatabase. I have the feature class used by the feature layer registered as traditional versioned. Global IDs are enabled. When I try to collaborate the feature layer from ArcGIS Enterprise to AGOL, I get the Failed to execute (Create Feature Service Replica) error in the server logs. I see that Replica Tracking is grayed out on the feature class.
What is missing here that needs to be set up to collaborate from our Enterprise to AGOL.
Thank you,
Mele
