Thanks Jayanta,
I have tried this before, the main issue with it the code is name dependent, for every sd that you need to create you should add the service name and workspace! I want a smarter tool or code that iterates all mxd in the file and create sd file.
In the link that you provided I should copy every mxd name to the code.
Ahmad Saleh
