I have a distributed collaboration set up between our ArcGIS enterprise portal and our ArcGIS Online account. I have several workspaces set up between several groups. I have been trying to sync a new data set in a new workspace but i continue to get the "completed_with_failures" message when i sync. The data is a referenced feature service from an enterprise database with sync turned on. I want to sync as a copy since agol users wont be able to access the data off of enterprise portal.
The sync error message is: "message": "Failed to import the data from the 'hosted feature layer' 'item_id' due to 'publishing error'. This 'hosted feature layer' item will NOT be imported."
When i look at AGOL i can see the layer is there but not in the workspace group it shoul be in, and when i look at the layer description i see "SQLite Geodatabase that will be used for publishing a feature service." So i suspect it is not finishing the publishing of the hosted feature service from enterprise to AGOL. so instead i get this remnant of the publishing process with some data in one of the layers but the rest have no records.
I have republished the layer as overwrite. i have deleted the layer form enterprise and republished as new. i have published a different layer to the workspace group. i have removed and recreated the entire workspace from the collaboration.
I'm out of ideas, and I don't find anything helpful when googling the error message. Any help is appreciated.
thanks,
Rayn
