Does my ArcServer have to be running https services to use https from the web adapter?
2010
03-28-2016 04:57 AM
AndrewDavis2
New Contributor III
I have a new IIS proxy server that I need to install WebAdapter on.  My ArcServer 10.2.2 is configured for http services.
Do I have to reset my ArcServer to https to really use the WebAdapter?
Andy
Tags (1)
AndrewDavis2
New Contributor III
Ok.. If I hadn't asked I would not have figured this out right afterwards.
My server has http / https configured for arcServer.  My proxy (running web adapter in the DMZ) has to have both 6080 and 6443 ports opened in the firewall to effectively communicate.  This is in the documentation, but alas..
Andy
AndrewDavis2
New Contributor III
Andy
MichaelRobb
Occasional Contributor III
Love when that happens..
I dont think you 'NEED' both if you are only running http.  6080 would be all you'd need in that case. 6443 wouldnt be used.
ArcGIS Server is default HTTP/HTTPS.
Ref: Ports used by ArcGIS Server—Installation Guides (10.4) | ArcGIS for Server
