ERROR 001272: Analyzer errors were encountered
6072
12-18-2012 09:54 AM
PaulSchneider
ERROR 001272: Analyzer errors were encountered (codes = 90)
When trying to publish a feature service of a single SDE feature class: default symbology, no definition query, non-versioned data.  All 'Analyze' results have been remedied.
ERROR 001272: Analyzer errors were encountered (codes = 52)
When trying to publish the same service with two non-versioned tables from the same data source
Suggestions anybody?
PaulSchneider
Took a little digging and some help from here
http://resources.arcgis.com/en/help/main/10.1/index.html#/00090_value_requires_a_registered_database...
Adjusted my connection settings and.... money.
Hope this helps someone else!
StephanieLong3
New Contributor II
THANK YOU THANK YOU THANK YOU!!!!!
