Hi Abhijit, Does publishing a service work on this portal? Notebook server creates a notebook item upon opening a notebook and this appears to be failing due to Index service not being available.
If you are unable to add an item or publish to Portal, then something is wrong with the configuration (out of disk space?) that needs to addressed before you can use notebooks.
Ravi
