Error with registering table view with enterprise sde database?
351
12-07-2023 05:05 AM
RPGIS
I been having issues as of late with registering a table view with our enterprise sde database. The table view queries data from another table in another SQL server database using a linked server object. Despite several attempts to register the table view; I cannot seem to get it to register. I don't know if anyone else has encountered issues like this, but any help would be greatly appreciated.
MarceloMarques
Register With Geodatabase (Data Management)—ArcGIS Pro | Documentation
You might need to upgrade the ArcSDE Geodatabase Repository to match the ArcGIS Pro version that you are using.
Client and geodatabase compatibility—ArcGIS Pro | Documentation
You do not have to keep your geodatabase and ArcGIS clients at the same release, but it is recommended that you do so. Geodatabases and client software are designed to work together, and if you let one get too many releases away from the other, you risk encountering problems or unexpected behavior.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
