I published a feature service from a view table in PostgreSQL to a standalone ArcGIS Server. I was able to view the feature layer in ArcGIS Online and was able query using the where clause.
However, when I open the attribute table, I get strange behaviours.
The feature count is wrong. The source layer has 914 features, but the attribute table shows 2,000.
When I select a row and click Center on Selection, nothing happened.
So, I checked the log file in ArcGIS Server Manager and saw this "Error: The table does not have an OID Field".
When I try to query at the REST endpoint using the Object ID, or return ID only or return count only, I get a "Unable to complete operation" error. The same "Error: The table does not have an OID Field" error appeared in the log file.
I have confirmed the feature layer has an ObjectID.
What did I miss?
