To enable single-sign-on via IWA (Active Directory accounts), open up IIS on the machine where the Portal for ArcGIS web adaptor is installed. Expand the connections list, until you see the web adaptor for Portal, listed under Default Web Site. Looking at the options, go into authentication (under the IIS grouping), and disable Anonymous Authentication then enable Windows Authentication. See this link for more details
