I just realized that when you connect to ArcGIS Server, the connection shows as a user connection, even though I used my arcgis server administrator credentials. Do you guys have any idea why? In ArcMap, if you want to connect to the server it gives you the options for user, publisher or administrator. Also, as a user in ArcGIS Pro, you are not able to delete services directly from the project pane. Thanks for your comments!
