Multiple GDBs vs Single GDB
50977
62
01-19-2016 08:21 AM
mpboyle
Occasional Contributor III
Our production enterprise system is currently 1 sde gdb (Sql Server 2014) with several (45 to be exact) datasets and 9 editable versions (based on department). The sheer number of datasets makes it a little cumbersome for users to find what they may be searching for.
I was wondering if anyone has tried breaking down a large sde gdb into several smaller gdbs, perhaps 1 sde gdb per department?  If so, is there is a performance advantage of having 1 large sde gdb versus several smaller sde gdbs?  Is response time better for smaller gdb versus larger gdbs?  Would reducing the number of versions have a benefit on performance?
I'm hoping to get some pros / cons of having 1 large sde gdb which is like a one-stop-shop for any GIS needs or several smaller sde gdbs meant for departmental needs.
Thanks!
MichaelSmith1
New Contributor III
SDE on a scalable database should never become 'unworkable'.  You may need to change tuning parameters, but it's not a limitation in SDE or your database.  Trust me, there are way bigger databases out there.
TheodoreF
Regarding File Geodatabases in ArcGIS Pro, is there a performance benefit from splitting one large FGDB into multiple FGDBs?
Let's say the dataset is purely vector features. And lots of them!
Theo
VinceAngelo
Esri Esteemed Contributor
Please ask new questions in a new thread.  "Lots" should be quantified, with more details on how the data is organized and being used.
- V
