We are using the out of the box JavaScript PrintTask with ArcGIS Server 10.2.2 Export Web Map Task. While the PDF is created, the Annotation Layers are not showing up.
Our annotation is in ArcSDE and it looks like what is happening is that the 'sublayers' of the annotation for the different annotation classes may be visible in the WebMap, but the parent annotation layer is not so the Export Web Map Task does not show this layers on the map.
We are also getting some very generic errors in the logs that I believe are related to this issue.
This sounds like a bug with the Export Web Map Task.
How do we get the Web Map sent to Export Web Map Task to show all of the annotation that is visible in the on screen map correctly?
Mele
