Publish Model result ,always lose corresponding
331
10-09-2012 02:14 AM
wangshixin
I created a model used to perform a clip operation, then the result is packaged in a zip file.This model can be run properly ,then perform the Publish operation. 'packaging in progress' window running a few minutes, and then lose the corresponding.I tried many times, and every time this problem occurs.
wangshixin
my environment: Windows Server 2008 x64 + ArcGIS Server x64 + ArcGIS Desktop x32 + Oracle 11g x32 + ArcSDE x32.  The ArcGIS Server, ArcGIS Desktop and Database in the same machine.  The attachment is my model and python script.
MLowry
Occasional Contributor II
What does it say in the Results window?
Menu: Geoprocessing -> Results
wangshixin
message:Packaging in progress...(Not Responding).
I found the memory of the ArcMap process growth to 164M, then it will lose corresponding.
Whether it can be prohibited that the SDE data copied to the server ? If can do this, the service release might not appear this case.
