Traceback (most recent call last): File "/arcgis/server/publisher/publish.py", line 175, in publish_dir self.create_sddraft(mds_name, sddraft) File "/arcgis/server/publisher/publish.py", line 95, in create_sddraft "wms_proxy," + mds_name File "/home/arcgis/miniconda2/envs/arcpy-publish/lib/python3.6/site-packages/arcpy/__init__.py", line 2119, in CreateImageSDDraft return arcgisscripting._createimageservicesddraft(raster_or_mosaic_layer, out_sddraft, service_name, server_type, connection_file_path, copy_data_to_server, folder_name, summary, tags) RuntimeError: Unable to connect to the provided target server: https://xxx.xxx.xxx.xxx:6443/arcgis/admin/
More info: using Linux Enterprise AMI on AWS EC2. Do I perhaps need to expose any outgoing ports to allow this sort of roundtrip connection?
I'm using VS Code, but running in bash terminal.
