Registering Database with server
4452
7
11-22-2013 06:04 AM
ErikBlake
Occasional Contributor III
Hello. So I am currently installing 10.1 server on our test environment. I am now trying to register my sde gdb with the server. When I try to do this from Catalog I get the following error message...
"Machine:Our server.company.org[Default SDE:
      The connection property set was missing a required propserty value was unrecognized.
       Connection was attempted with an older version of SQL Server client communication software that is not compatible with the SQL Server database server.]
We are still currently using our 10 environment so do I need to upgrade our sde to 10.1 or ?....
Erik
NidhinKarthikeyan
It will be available in ArcGIS Server Software DVD.
NidhinKarthikeyan
You have to install SQL Server native client on the machine where ArcGIS Server is installed. Make sure you select 64 bit client for ArcGIS Server.
ErikBlake
Nidhinkn
Thanks for the response. Where do I find SQL server native client? Is it a download from microsoft? If so is it "Microsoft ODBC Driver 11 for SQL Server" or is it "Microsoft SQL Server 2008 R@ Feature Pack" Or something else.
Erik
NidhinKarthikeyan
ErikBlake
Thank you.
ErikBlake
Nidhinkn
One more question. what folder is this located in. Or is it an extension when installing server. I have downloaded all server software from our customer care site. Or this a special request?
ErikBlake
Never mind I found it. Thanks again
NidhinKarthikeyan
I was away from desk. It will be in folder named 'Support'.
