I try to setup a feature service for offline use with collector for arcgis.
I want to make an inspection table that I can edit in the field.
The table and the feature service has to attributes that I want to use for the relationship. These two attributes are maintained outside this database.
I use ArcGIS server 10.4 and Sql-server express 2012.
From this blogpost: Related Tables – Exploring New Ways to use Collector for ArcGIS | ArcGIS Blog
and this help page: Prepare data for offline use—Documentation | ArcGIS for Server
it seems that you have to use globalID in the relationship to get it work off line. But if I have a feature class with GlobalID and a table with a globalID and make a relationship between those to GlobalID, I will not get any matching records! Thats logical and I have tested it in ArcMap. Iam able to make new rows in the related table, but there is no matches afterwards.
So my question is:
How do I establish this join/relation? For me, it seems logical to use GlobalID in the featureclass to something else in the table. But what? I tried to make a ordinary text field. That did not work. I found this topic tonight:
ArcGIS collector and related table - Geographic Information Systems Stack Exchange
That suggest to use a GUID-field in the table. Is that the solution?
