Remove shapefiles from a list
1975
06-27-2017 03:01 PM
AhmadSALEH1
Occasional Contributor III
Hello,
I am trying to write the following python script which removes all shapefiles (any word that ends with .shp) from a list
#Assign variables to the shapefiles
park="Parks_sd.shp"
sewer="Sewer_Main_sd.shp"
water="water"
street="street"
#Create a list of shapefile variables
datalist=[park,sewer,water,street]
# prints the list before the loop to compare the results
print datalist
    for x in datalist:
          if x.endswith(".shp"):
            datalist.remove(x)
print datalist
But the result looks like this
['Parks_sd.shp', 'Sewer_Main_sd.shp', 'water', 'street']
['Sewer_Main_sd.shp', 'water', 'street']
the code succeeds to remove the first item in the list but fails to remove the second one!
What might be the issue here?
JonathanQuinn
Esri Notable Contributor
You shouldn't be iterating through a list while modifying it.  See the following posts:
Python: Removing list element while iterating over list - Stack Overflow
Delete item from list in Python while iterating over it - Stack Overflow
python - Remove items from a list while iterating - Stack Overflow
You can do this instead:
sewer="Parks_sd.shp"
park="Sewer_Main.shp"
water="water"
street="street"
for x in list(datalist):
        datalist.remove(x)
print(datalist)
JonathanQuinn
water="water"
street="street"
        datalist.remove(x)
print(datalist)
AhmadSALEH1
Thanks Jonathan, it worked now, this is helpful. By the way why I cannot see " Mark as correct answer" icon next to your answer!
