Rename a folder in Arcgis server manager
3111
10-13-2016 02:44 AM
DharmaRajan
In Arcgis server manager, a folder was created and services are published inside it. Now I want to rename that folder. But the 'Rename' option was disabled. How to fix this issue? Kindly suggest me.
FrédéricPRALLY
According to the documentation you cannot renamed a folder if it contains services.
You can only renamed it from ArcCatalog if the folder is empty.
Best regards,
Fred
FrédéricPRALLY
Best regards,
Fred
RyanSutcliffe
Occasional Contributor II
Just want to confirm: Is this still really the case? We can't even spin down the ArcGIS Server site and rename the directories manually? (Add a GIS server folder in ArcGIS Desktop—Documentation | Documentation for ArcGIS Enterprise)
by Anonymous User
Not applicable
Yes, this is a known limitation. ArcGIS Server folders cannot be renamed if they contain a service:
Add a GIS server folder in ArcGIS Desktop—Publish services | Documentation
As long as the folder is empty, you can rename it. Once the folder contains a service, you cannot rename the folder. You cannot drag services between folders.
