Hey Guys,
We're trying to publish a very large MXD (60mb) and associated SD file (10mb) to ArcGIS Server and we keep getting a failed error after around 30 minutes or so.
For context, we have a 10.6.1 AGS, which is federated. The service we are trying to publish has a lot of layers in it (over 100) and has an associated pre-built cache, which sits on a mapped network drive.
We've tried to publish it through ArcGIS Desktop and also by uploading the SD file to the Server Manager and on both occasions we get this same log results after around 30 minutes of waiting for the publishing to complete:
Token Renewal Failed (No credentials available). 10014
Core server call to create service failed (/admin/createService). 23850
Failed to create the service.: Token renewal failed (No credentials available). 23836
Token renewal failed (No credentials available). 100104
Error executing tool: Publish Service Definition – Failed to execute (Publish Service Definition). 20010
Apologies, I am not able to copy the full log. The numbers to the right are the associated error code.
I'm guessing the token it grabs before it publishes may have a 30 minute expiry time and for some reason it is unable to get another one?
Does anyone have any advice for publishing large services? or know if there are any other workaround to get around what we are experiencing?
Cheers,
Jordan
