Hi Jonathan,
In my case I need to migrate the ArcGIS Server 10.4.1 to a new server with different hostname and IP address. I would need to uninstall ArcGIS Server on the old server and freshly install ArcGIS Server on the new server.
I am using a lot of map services and some feature services. Also I have Oracle geodatabase connections, and folders having data registered with ArcGIS Server. There are no users or roles except for the site administrator. Also, 1 site has 1 GIS server machine only.
Also web adaptor has been configured with IIS, so I'm planning to install ArcGIS Server and configure Web Adaptor on the new server. However,
Before uninstalling ArcGIS Server from old server, what steps need to be taken.
After installing ArcGIS Server and configuring web adaptor in new server, what steps need to be taken.
I want to minimize the work as much as possible. I don't want to publish each and every service again, or register all the data sources again.
Thanks for your help.
Regards,
Apurv
