The installed ArcGIS server 10.4.1 on top of 10.3.1 fails to start,
2035
11
09-02-2016 01:19 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why the Installed ArcGIS server 10.4.1 on top 10.3.1 fails to start (attached).
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Can you please restart ArcGIS server process from services.msc .
Then try to login again on Server manager
From your screen looks like ArcGIS server is up and running but slow responce.
JamalNUMAN
Thanks Avinash for the help
I have restarted the ArcGIS Server service but the issue persist to exists.
What other things I might still need to apply?
Jamal Numan
by Anonymous User
Not applicable
Hi Jamal,
Are you able to make ArcGIS server connection in ArcMap Catalogue ?
if yes then its web browser issue.
Else some thing wronge with server manager.
please use this also
http://localhost:6080/arcgis/admin/login
to check server services...
Please give feedback.... of your findings.
JamalNUMAN
Thanks Avinash.
I’m still able to access the admin and connecting from Catalog. However, I’m not able to publish.
Do you recommend to uninstall\re-install?
Jamal Numan
RebeccaStrauch__GISP
hi Jamal,
have you installed the patches for 10.4.x, in particular Esri Support 10.4 (10.4.1)  which is the publishing patch, but seems to resolve quite a few issues.
Esri® announces the ArcGIS for Server Publishing Patch. This patch addresses failures while publishing and fixes a performance slow down when publishing GIS services. This patch deals specifically with the issues listed below under Issues Addressed with this patch.
you should be able to find all the patches off that link, or there is a "check for updates" utility that is installed with 10.4 that should also work.  I'm not at my server machine right now, but check under Start - All programmers - ArcGIS-server    The tool should be easy to find.
edit: added patch description....   iPad tends to eat my response if I don't  do this in two steps.
JamalNUMAN
Thanks Rebecca,
I have already uninstalled the 10.4.1 and reinstall it. I’m again in trouble as I got the error below “failed to create the site”.
Jamal Numan
Doing a web search on "ArcGIS server failed to create site" returns  quite a few Q&A , but most give a more specific or longer error message. But many refer to firewall or antivirus blocking things. I  assuming since this was an existing machine that those things have been ruled out?
when you uninstalled and reinstalled, did you rename the c:\arcgisserver folder so it could be recreated?
here are a few of the links that may help, even if not the exact same error message, the solution might help...
Error: Failed to create the site. Failed to create the service 'System/CachingTools.GPServer'
I havent looked thru all these yet, but some bug listings and other technical articles (other than link above, I don't think others apply)
Esri Support Search-Results
And from the help docs
Creating a new site—Documentation (10.4) | ArcGIS for Server
Deleting a site—Documentation (10.4) | ArcGIS for Server
by Anonymous User
Not applicable
Hi Jamal,
Please check for folder permission.
by Anonymous User
Not applicable
Hello jamal,
You are still facing issue or it's resolved.
if it's then please marked as Answered...
