The 10.9 web adaptor on Linux is giving me trouble.
I have a machine with Ubuntu 20.04, per the requirements.
I tried initially with Tomcat 9.0.31. Ran into these issues, so I manually reinstalled Tomcat 9.0.19 per the requirements.
I have the Tomcat server configured to use ports 80 and 443 instead of the default. The certificate/SSL setup is valid and working.
The "arcgis.war" file deploys to Tomcat just fine. No error.
No matter what I've tried, the Web Adaptor only gives me this web page ... (no, the URL is not secret)
I have tried to use the CLI (on the same machine as Tomcat) to configure it:
./configurewebadaptor.sh -m server -w http://geodata109-www.stone-env.net/arcgis/webadaptor -g https://geodata109-ags.stone-env.net:6443 -u Nope -p HaHaNope -a false
But this results in the error "Unable to connect to WebAdaptor URL : https://geodata109-www.stone-env.net/arcgis/webadaptor"
I've tried just using "localhost" in all of my configuration instead, but that has resulted in the same issue. It seems that while the adaptor is deployed and accessible, it is missing some key "something" and there is really nothing in the documentation that clarifies what is missing.
The only error in the Catalina log is this: "20-Aug-2021 18:07:25.628 SEVERE [https-openssl-apr-443-exec-22] com.esri.arcgis.server.wa.servlet.WebAdaptorConfigServlet.service null"
I get a warning which does seem relevant, but I see no documentation anywhere about this file: "20-Aug-2021 18:09:59.269 WARNING [https-openssl-apr-443-exec-30] com.esri.arcgis.server.wa.data.Config.initialize Unable to load web_adaptor.properties configuration file"
So friends ... any ideas?
