What is the differance between the "Python Toolbox" and the "Script Tool"
3318
07-13-2017 01:52 PM
AhmadSALEH1
I wonder what is the difference between the two tools, the one that created automatically when creating a new “Toolbox.pyt” and the other one that I can create manually inside “Toolbox (2).tbx” which will have the name Script.
What I figured out till now is that in order to make Script tool work I should go through the wizard and load my python script and parameters, while the python tool box dosent have a wizard and the code will be written inside the pyt file using the IDE environment.
I would like to know which one is better to use? And which one is more stable and more efficient? If there are any limitations on each on of them, and so on.
