We would like to be able to apply a single filter to multiple layers in the map and related widgets in Experience Builder. The Filter widget has a very nice user experience which exposes multiple fields from a single layer. The end user can then select unique values from fields in that layer and a map/table can be filtered accordingly.
We would like to see the filter widget functionality extended to allow filtering on other multiple other layers in the map. I can imagine that the configuration of of the Filter Widget for multiple layers would be composed of either:
- Allowing Message Actions on the Filter Widget. Based on a filter being applied, send a message to other layers to filter based on a common field.
- Creating a Filter based on multiple Data Sources. Instead of selecting a single data source, allow multiple data sources to be selected and allow the app builder to select a common field across all data sources.
This is not an idea to support the migration of the Group Filter Widget. The Group Filter widget in Web AppBuilder has its own unique user experience which is quite different to the Filter Widget in Experience Builder.
@Jianxia - This is duplication of various other submitted ideas that are open at the moment, and lots of questions on the Community about if this is coming. It would be nice to collate many of these so users can upvote the central common idea. These include:
Thanks All.
