Action "Record selection changes" with Trigger "Select data records" stopped working
1082
23
02-29-2024 03:22 AM
kabukow
Hi, we had multiple Experience Apps set up with a map actions and trigger "Select data records" where one layer while selected caused selection of another layer by common ID. These actions stopped working today. We tested that on different apps, using different datasets both of which function properly and are not corrupted in any way except for the above. Is this a bug that ESRI is working on or can it be fixed differently?
Thank you
Jianxia
@stariq22 thanks for the reproducible sample. We are working on it.
Jianxia
@stariq22 @JustinCurtis2, the location search issue will be addressed tonight (PST). Could you please help confirm the fix on Friday (PST)? Thanks!
stariq22
New Contributor II
@Jianxia The issue has been resolved. Thank you for all your help!
Jianxia
Great!  @stariq22
