Chart Widget
734
07-19-2021 08:40 PM
RodWoodfordOld
Occasional Contributor III
Hi, Is it possible to make the chart widget interact with the map? Eg when the map zooms the chart updates to reflect the map extent.
cheers
2 Solutions
JonathanMcDougall
@RodWoodfordOld
Absolutely, just create a chart then create an action on that chart to filter the map (framework) and setup the common field between the chart and map data.
Equally, if you have an actin on the map when the extent changes, the chart will react accordingly too.
RodWoodfordOld
Thanks Jonathan for the help.
JonathanMcDougall
@RodWoodfordOld
RodWoodfordOld
