The client has a specific color requirement for widgets inside which are provided within the widget controller.
Widget SVG Icon: Is there a possibility to change the color of individual widgets inside the widget controller.
This is what was obtained from experience builder as you can see all widgets have same color.
But I want the icons to be as below.
This was achieved using web app builder.
Thanks.
The background color of these icons is not independently changeable. The icon color itself can be changed. https://community.esri.com/t5/experience-builder-tips-and-tricks/changing-the-icons-and-titles-of-wi...
Another possible solution is to put each widget in its own Widget Controller.
@JeffreyThompson2 I am trying to make my widget controller buttons look the same as the map buttons (like home_button.PNG). In my map, when I hover over or click on a button, the icon changes color. I like how that looks, but when I try to change that for my widget controller buttons, I can't change the icon color with a hover or select, only the background or text (like map_layers.PNG). Am I missing something or is this functionality just not available?
The icon colors cannot be changed on hover/select.
