Hi Friends
i have been trying to create a cluster point with the DBSCAN method based on a python script I found on Github. I've tried changing the data type of the feature input parameter (from "DEfile" to "DEFeatureClass"), but it always fails when executed.
Here is the script and the error:
import arcpy
import math
class Toolbox(object):
def __init__(self):
self.label = "Dbscan toolbox"
self.alias = "Dbscan"
self.cs = 0
# List of tool classes associated with this toolbox
self.tools = [DbscanAlgorithm]
class DbscanAlgorithm(object):
def __init__(self):
self.label = "Dbscan Algorithm"
self.description = ""
def getParameterInfo(self):
#Define parameter definitions
# Input Features parameter
in_file = arcpy.Parameter(
displayName="Input File",
name="in_features",
datatype="DEFile",
parameterType="Required",
direction="Input")
in_file.filter.list = ['etc']
# Distance parameter
distan = arcpy.Parameter(
displayName="Distance",
name="Distance",
datatype="GPLong",
direction="Input")
# Set an acceptable range of 0 to 1000
distan.filter.type = "Range"
distan.filter.list = [0, 1000] # Aqui se determina el rango de la distancia permitida entre puntos.
distan.value = ""
# Minimum Points parameter
mpt= arcpy.Parameter(
displayName="Minimum Points",
name="minpt",
datatype="GPLong",
direction="Input")
mpt.filter.type = "Range"
mpt.filter.list = [0, 100] # Aqui se determina el minimo de puntos que puede conformar un cluster.
mpt.value = ""
# Derived Output Features parameter
out_features = arcpy.Parameter(
displayName="Output Features",
name="out_features",
datatype="GPFeatureLayer",
parameterType="Derived",
direction="Output")
out_features.parameterDependencies = [in_file.name]
out_features.schema.clone = True
parameters = [in_file, distan, mpt, out_features]
return parameters
def updateMessages(self, parameters): #optional
return
def execute(self, parameters, message):
inFeatures = parameters[0].valueAsText
d = parameters[1].valueAsText
mp = parameters[2].valueAsText
outFeatures = parameters[3].valueAsText
arcpy.AddMessage(d)
arcpy.AddMessage(mp)
outFeat = ""
v = []
for arr in xrange(0, outFeatures.__len__()):
if outFeatures[arr] == "\\":
v = arr
for j in xrange(0, v):
outFeat = outFeat + outFeatures[j]
x = datetime.datetime.now()
outFeatures = outFeat + "\\Dbscan_"+str(d)+"_"+str(mp)
arcpy.AddMessage(outFeatures)
path = inFeatures
e = int(d)
minpt = int(mp)
read = Archivo()
read.coordinate(path)
points = read.getCoordinate()
id_p = read.id_point
util = Utility()
scan = Dbscan(points)
cluster = scan.applyDbscan(e, minpt)
shape = Shapefile()
pointShape = []
clus = []
id_points = []
nume = 0
for i in xrange(0, cluster.__len__()):
num = int(i+1)
for j in xrange(0, cluster[i].__len__()):
for l in xrange(0, points.__len__()):
p = Point(cluster[i][j].getX(), cluster[i][j].getY())
if util.equalPoints(p,points[l]) == True:
pointShape.append(p)
clus.append(num)
id_points.append(id_p[l])
arcpy.AddMessage(str(id_points[nume])+", "+str(clus[nume])+", "+str(p.getX())+", "+str(p.getY()))
nume = nume + 1
if os.name == "nt":
path = "C:\Windows\Temp\Point_Cluster.txt"
elif os.name == "posix":
path = "\tmp\Point_Cluster.txt"
outfile = open(path, 'w')
for l in clus:
outfile.write(str(l)+'\n')
outfile.close()
if os.name == "nt":
path = "C:\Windows\Temp\Point_Id.txt"
path = "\tmp\Point_Id.txt"
for l in id_points:
outfile.close()
shape.shape(pointShape, outFeatures)
# _________________________________________________
from decimal import Decimal
import os
cs = 0
class Shapefile:
def shape(self, ptList, outDbscan):
pt = arcpy.Point()
ptGeoms = []
for p in ptList:
pt.X = float(p.getX())
pt.Y = float(p.getY())
ptGeoms.append(arcpy.PointGeometry(pt))
nameShape = arcpy.CopyFeatures_management(ptGeoms, outDbscan)
# coordinateSystem = "GEOGCS['GCS_MAGNA',DATUM['D_MAGNA',SPHEROID['GRS_1980',6378137.0,298,257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"
coordinateSystem = "PROJCS[MAGNA_Ciudad_Bogota,GEOGCS['GCS_MAGNA',DATUM['D_MAGNA',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',92334.879],PARAMETER['False_Northing',109320.965],PARAMETER['Central_Meridian',-74.14659166666668],PARAMETER['Scale_Factor',1.000399803265436],PARAMETER['Latitude_Of_Origin',4.680486111111112],UNIT['Meter',1.0]]"
# nameShape = r"C:\Users\Emmanuel\Desktop\Points.shp"
arcpy.DefineProjection_management(nameShape, coordinateSystem)
arcpy.AddXY_management(nameShape)
arcpy.AddField_management(nameShape, 'cluster', 'TEXT')
expression1 = "getClass(!FID!, 1)"
expression2 = "getClass(!FID!, 2)"
codeblock = """
cs = []
import os
def getClass(indice, file):
if indice == 0:
if file == 1:
if os.name == "nt":
elif file == 2:
if os.name == "nt":
infile = open(path, 'r')
for line in infile:
global cs
cs.append(line)
infile.close()
os.remove(path)
return cs[indice]
arcpy.CalculateField_management(nameShape, 'id',expression1, 'PYTHON_9.3', codeblock)
arcpy.CalculateField_management(nameShape, 'cluster',expression2, 'PYTHON_9.3', codeblock)
class Dbscan:
def __init__(self, date):
self.util = Utility()
self.util.defDate(date)
self.pointList = date
self.resultList = []
self.e = 0
self.minpt = 0
self.Neighbours = []
def applyDbscan(self, dist, minpt):
self.e = dist # Interfaz.dU;
self.minpt = minpt # Interfaz.mP;
self.util.VisitList = []
index2 = 0;
while self.pointList.__len__() > index2:
p = self.pointList[index2]
if self.util.isVisited(p) == False:
self.util.Visited(p)
self.Neighbours = self.util.getNeighbours(p,dist)
if self.Neighbours.__len__() >= self.minpt:
ind = 0;
while self.Neighbours.__len__() > ind:
r = self.Neighbours[ind]
if self.util.isVisited(r) == False:
self.util.Visited(r)
Neighbours2 = self.util.getNeighbours(r,dist)
if Neighbours2.__len__() >= self.minpt:
self.Neighbours = self.util.merge(self.Neighbours, Neighbours2)
ind = ind + 1
print "N " , self.Neighbours.__len__()
self.resultList.append(self.Neighbours)
index2 = index2 + 1
return self.resultList
def reset():
self.pointList = []
class Point:
def __init__(self,a,b):
self.X = a
self.Y = b
def getX(self):
return self.X
def getY(self):
return self.Y
class Archivo:
def coordinate(self, path):
self.coordina = []
self.id_point = []
with open(path) as data_f:
for l in data_f.readlines():
line = ""
cId = ""
cX = ""
cY = ""
court1 = 0
court2 = 0
line = l.strip()
for i in xrange(0, line.__len__()):
if line[i] == "," and court1 == 0:
court1 = i
elif line[i] == "," and court2 == 0:
court2 = i
if i < court1:
cId += line[i]
elif i > court1 and i < court2:
cX += line[i]
elif i > court2:
cY += line[i]
X = float(cX)
Y= float(cY)
p = Point(cX,cY)
val = False
for l in self.coordina:
if self.util.equalPoints(l,p)==True:
val = True
break
else:
val = False
if val == False:
self.id_point.append(cId)
self.coordina.append(p)
data_f.close()
# cont = 0
# for i in self.coordina:
# print cont, " ", i.getX(), " ", i.getY()
# cont = cont + 1
return self.coordina
def getCoordinate(self):
def reset(self):
self.coordina = []
self.id_point = []
class Utility:
def __init__(self):
self.VisitList = []
def getDistance(self,p,q):
dx = float(p.getX()) - float(q.getX())
dy = float(p.getY()) - float(q.getY())
distance = math.sqrt(math.pow(dx,2) + math.pow(dy,2))
return distance
def getNeighbours(self,p, e):
neigh = []
points = []
points = self.getList()
for i in points:
q = i
if self.getDistance(p,q) <= e:
neigh.append(q)
return neigh
def Visited(self,d):
self.VisitList.append(d)
def isVisited(self,c):
if c in self.VisitList:
return True
else:
return False
def merge(self,a,b):
it5 = b
for i in it5:
t = i
if t not in a:
a.append(t)
return a
def getList(self):
return self.newList
def equalPoints(self,m,n):
if m.getX()==n.getX() and m.getY()==n.getY():
return True
else:
return False
def reset(self):
VisitList = []
def defDate(self, date):
self.newList = date
