Failed Execute (Dbscan Algorithm)
293
01-17-2023 03:30 AM
DimasPutrapangestu
Hi Friends
i have been trying to create a cluster point with the DBSCAN method based on a python script I found on Github. I've tried changing the data type of the feature input parameter (from "DEfile" to "DEFeatureClass"), but it always fails when executed.
Here is the script and the error:
import arcpy
import math
class Toolbox(object):
    def __init__(self):
        self.label =  "Dbscan toolbox"
        self.alias  = "Dbscan"
	self.cs = 0
        # List of tool classes associated with this toolbox
        self.tools = [DbscanAlgorithm]
class DbscanAlgorithm(object):
    def __init__(self):
        self.label       = "Dbscan Algorithm"
        self.description = ""
    def getParameterInfo(self):
        #Define parameter definitions
        # Input Features parameter
        in_file = arcpy.Parameter(
            displayName="Input File",
            name="in_features",
            datatype="DEFile",
            parameterType="Required",
            direction="Input")
        in_file.filter.list = ['etc']
        # Distance parameter
        distan = arcpy.Parameter(
            displayName="Distance",
            name="Distance",
            datatype="GPLong",
            direction="Input")
	# Set an acceptable range of 0 to 1000
    	distan.filter.type = "Range"
    	distan.filter.list = [0, 1000] #  Aqui se determina el rango de la distancia permitida entre puntos.
	distan.value = ""
	# Minimum Points parameter
        mpt= arcpy.Parameter(
            displayName="Minimum Points",
            name="minpt",
            datatype="GPLong",
            direction="Input")
    	mpt.filter.type = "Range"
    	mpt.filter.list = [0, 100] #  Aqui se determina el minimo de puntos que puede conformar un cluster.
	mpt.value = ""
	# Derived Output Features parameter
        out_features = arcpy.Parameter(
            displayName="Output Features",
            name="out_features",
            datatype="GPFeatureLayer",
            parameterType="Derived",
            direction="Output")
        out_features.parameterDependencies = [in_file.name]
        out_features.schema.clone = True
        parameters = [in_file, distan, mpt, out_features]
        return parameters
    def updateMessages(self, parameters): #optional
        return
    def execute(self, parameters, message):
        inFeatures  = parameters[0].valueAsText
        d = parameters[1].valueAsText
	mp = parameters[2].valueAsText
	outFeatures = parameters[3].valueAsText
        arcpy.AddMessage(d)
	arcpy.AddMessage(mp)
	outFeat = ""
	v = []
	for arr in xrange(0, outFeatures.__len__()):
	    if outFeatures[arr] == "\\":
		v = arr
	for j in xrange(0, v):
	    outFeat = outFeat + outFeatures[j]
	x = datetime.datetime.now()
	outFeatures = outFeat + "\\Dbscan_"+str(d)+"_"+str(mp)
	arcpy.AddMessage(outFeatures)
	path = inFeatures
        e = int(d)
        minpt = int(mp)
        read = Archivo()
        read.coordinate(path)
        points = read.getCoordinate()
        id_p = read.id_point
        util = Utility()
        scan = Dbscan(points)
        cluster = scan.applyDbscan(e, minpt)
	shape = Shapefile()
    	pointShape = []
	clus = []
	id_points = []
	nume = 0
        for i in xrange(0, cluster.__len__()):
	    num = int(i+1)
            for j in xrange(0, cluster[i].__len__()):
                for l in xrange(0, points.__len__()):
                    p = Point(cluster[i][j].getX(), cluster[i][j].getY())
                    if util.equalPoints(p,points[l]) == True:
			pointShape.append(p)
			clus.append(num)
			id_points.append(id_p[l])
			arcpy.AddMessage(str(id_points[nume])+", "+str(clus[nume])+", "+str(p.getX())+", "+str(p.getY()))
			nume = nume + 1
	if os.name == "nt":
	    path = "C:\Windows\Temp\Point_Cluster.txt"
	elif os.name == "posix":
	    path = "\tmp\Point_Cluster.txt"
	outfile = open(path, 'w')
	for l in clus:
		outfile.write(str(l)+'\n')
	outfile.close()
	if os.name == "nt":
	    path = "C:\Windows\Temp\Point_Id.txt"
	    path = "\tmp\Point_Id.txt"
	for l in id_points:
	outfile.close()
	shape.shape(pointShape, outFeatures)
#  _________________________________________________
from decimal import Decimal
import os
cs = 0
class Shapefile:
    def shape(self, ptList, outDbscan):
        pt = arcpy.Point()
        ptGeoms = []
        for p in ptList:
            pt.X = float(p.getX())
            pt.Y = float(p.getY())
            ptGeoms.append(arcpy.PointGeometry(pt))
	nameShape = arcpy.CopyFeatures_management(ptGeoms, outDbscan)
	#  coordinateSystem = "GEOGCS['GCS_MAGNA',DATUM['D_MAGNA',SPHEROID['GRS_1980',6378137.0,298,257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"
	coordinateSystem = "PROJCS[MAGNA_Ciudad_Bogota,GEOGCS['GCS_MAGNA',DATUM['D_MAGNA',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',92334.879],PARAMETER['False_Northing',109320.965],PARAMETER['Central_Meridian',-74.14659166666668],PARAMETER['Scale_Factor',1.000399803265436],PARAMETER['Latitude_Of_Origin',4.680486111111112],UNIT['Meter',1.0]]"
	#  nameShape = r"C:\Users\Emmanuel\Desktop\Points.shp"
	arcpy.DefineProjection_management(nameShape, coordinateSystem)
	arcpy.AddXY_management(nameShape)
	arcpy.AddField_management(nameShape, 'cluster', 'TEXT')
	expression1 = "getClass(!FID!, 1)"
	expression2 = "getClass(!FID!, 2)"
	codeblock = """
cs = []
import os
def getClass(indice, file):
    if indice == 0:
	if file == 1:
	    if os.name == "nt":
	elif file == 2:
	    if os.name == "nt":
	infile = open(path, 'r')
	for line in infile:
	    global cs
            cs.append(line)
        infile.close()
	os.remove(path)
    return cs[indice]
	arcpy.CalculateField_management(nameShape, 'id',expression1, 'PYTHON_9.3', codeblock)
	arcpy.CalculateField_management(nameShape, 'cluster',expression2, 'PYTHON_9.3', codeblock)
class Dbscan:
    def __init__(self, date):
        self.util = Utility()
        self.util.defDate(date)
        self.pointList = date
        self.resultList = []
        self.e = 0
        self.minpt = 0
        self.Neighbours = []
    def applyDbscan(self, dist, minpt):
        self.e = dist  #  Interfaz.dU;
        self.minpt = minpt #  Interfaz.mP;
        self.util.VisitList = []
        index2 = 0;
        while self.pointList.__len__() > index2:
            p = self.pointList[index2]
            if self.util.isVisited(p) == False:
                self.util.Visited(p)
                self.Neighbours = self.util.getNeighbours(p,dist)
                if self.Neighbours.__len__() >= self.minpt:
                    ind = 0;
                    while self.Neighbours.__len__() > ind:
                        r = self.Neighbours[ind]
                        if self.util.isVisited(r) == False:
                            self.util.Visited(r)
                            Neighbours2 = self.util.getNeighbours(r,dist)
                            if Neighbours2.__len__() >= self.minpt:
                                self.Neighbours = self.util.merge(self.Neighbours, Neighbours2)
                        ind = ind + 1
                    print "N " , self.Neighbours.__len__()
                    self.resultList.append(self.Neighbours)
            index2 = index2 + 1
        return self.resultList
    def reset():
        self.pointList = []
class Point:
    def __init__(self,a,b):
        self.X = a
        self.Y = b
    def getX(self):
        return self.X
    def getY(self):
        return self.Y
class Archivo:
    def coordinate(self, path):
        self.coordina = []
        self.id_point = []
        with open(path) as data_f:
            for l in data_f.readlines():
                line = ""
                cId = ""
                cX = ""
                cY = ""
                court1 = 0
                court2 = 0
                line = l.strip()
                for i in xrange(0, line.__len__()):
                    if line[i] == "," and court1 == 0:
                        court1 = i
                    elif line[i] == "," and court2 == 0:
                        court2 = i
                    if i < court1:
                        cId += line[i]
                    elif i > court1 and i < court2:
                        cX += line[i]
                    elif i > court2:
                        cY += line[i]
                X = float(cX)
                Y= float(cY)
                p = Point(cX,cY)
                val = False
                for l in self.coordina:
                    if self.util.equalPoints(l,p)==True:
                        val = True
                        break
                    else:
                        val = False
                if val == False:
                    self.id_point.append(cId)
                    self.coordina.append(p)
        data_f.close()
        #  cont = 0
        #  for i in self.coordina:
            #  print cont, "  ", i.getX(), "  ", i.getY()
            #  cont = cont + 1
        return self.coordina
    def getCoordinate(self):
    def reset(self):
        self.coordina = []
        self.id_point = []
class Utility:
    def __init__(self):
        self.VisitList = []
    def getDistance(self,p,q):
        dx = float(p.getX()) - float(q.getX())
        dy = float(p.getY()) - float(q.getY())
        distance = math.sqrt(math.pow(dx,2) + math.pow(dy,2))
        return distance
    def getNeighbours(self,p, e):
        neigh = []
        points = []
        points = self.getList()
        for i in points:
            q = i
            if self.getDistance(p,q) <= e:
                neigh.append(q)
        return neigh
    def Visited(self,d):
        self.VisitList.append(d)
    def isVisited(self,c):
        if c in self.VisitList:
            return True
        else:
            return False
    def merge(self,a,b):
        it5 = b
        for i in it5:
            t = i
            if t not in a:
			a.append(t)
        return a
    def getList(self):
        return self.newList
    def equalPoints(self,m,n):
        if m.getX()==n.getX() and m.getY()==n.getY():
            return True
        else:
            return False
    def reset(self):
        VisitList = []
    def defDate(self, date):
        self.newList = date
