Hi, we are running an 11.1 Portal and no issues with the built in ExB 1.10. But using the latest 1.12 external from the Portal with an app registration and having troubles.
The Filter widget is not loading the unique value list and seeing a handful of errors in the console. The main one being it cannot execute a query against the AGS endpoint.
Example Endpoint: https://x.domain.com/arcgis/rest/services/Global/Task/MapServer/0/query
Example WHERE: (FIELD_NAME IS NOT NULL AND CHAR_LENGTH(FIELD_NAME) > 0)
With some trial and error testing, see the issue is with the CHAR_LENGTH function. The error in Server Manager is: "'CHAR_LENGTH' is not a recognized built-in function name.]". The underlying geodatabase is on SQL Server 2016.
Any way to bypass this CHAR_LENGTH() check? Or have it use LEN() instead? The seems to be a bug depending on the underlying database that was introduced between 1.10 and 1.12.
Thanks for any help!
