I'm relatively new to Experience Builder, so I wanted to determine if the following is even possible. Namely, is there a way that a feature can be zoomed into on a map and then display features/points from another layer that fall within a set distance?
The general scenario is in regards to fire hydrant proximity. Our Fire Department would like to enter an address, have the map zoom to that property at a set zoom level, and then only display fire hydrants within 1,000 meters of the property. I'm not sure of Exp. Builder's query/buffer capabilities to know if this could be done on the fly.
Any insights are greatly appreciated!
-Matt, Farmington Hills, MI
