Is this a couple more bugs?
1 The vertical exaggeration setting does not work. In fact the vertical scale is so small that the 3D option is virtually useless. It used to work on the previous version of Explorer.
2 When I removed the My Default Map.nmf file and added only a single Map layer the start-up time went from 27 secs down to 8 secs. That was very impressive.
a. As I added more layers it got slower. Then I added 40 GPX files. That made it VERY slow.
b. With around 40 GPX files turned on the performance on pan and zoom is VERY slow. Almost unusable.
Is there a way to improve this performance?
Thanks
Barry
