Hi Mark,
I'm working on the XSL coding in the HTML Popup properties now. I'm not a programmer anymore (not since Avenue!), so I'm trying to figure this out. I find this a frustrating process for something that seems like it should be simpler.
Here's my dilemma, my hyperlinked attribute is already set-up for a Hyperlink Script in ArcGIS. The reason is my data is on a really long network path, so I cut off the majority of the filepath and added it to the path variable like so...
Function OpenLink ([PrjDrawing])
Dim objShell
Dim path (i.e. RecordDrawing1.pdf)
path = "\\SERVER\Directory\Directory\Directory\Directory\"&[PrjDrawing]
..you get the idea I'm sure
This process cleared up a lot of repetitive clutter in my geodatabase. I'd like this same process in ArcGIS Desktop. Can I concatenate the "C:\Directory\Directory\" to my attribute field value in the XSL as well so I don't have to change my attribute values in the database to satisfy disconnected map use in Explorer Desktop?
