Can't see attribute data via click on layers and layer package
2766
09-07-2010 12:03 PM
by Anonymous User
Not applicable
Original User: bent_olsen
But a click on af shape file layer or a gdb featureclass layers opens a window containing attribute data!
Why this difference?
Any help out there?
by Anonymous User
Not applicable
Original User: tmsmatt
For the identify function to work with layers and layer packages, you will need to check an option to show this in the layer properties in ArcGIS Desktop. (shown in the screenshot) This additional step will allow you to control how the attribute dialog box appears in ArcGIS Explorer.
MichaelBranscomb
Esri Frequent Contributor
Hi bent_olsen,
If you're still having trouble after following the advice below, can you post a Layer Package sample here on the forum and I will test it.
Regards
Mike
