Hello.
I'm trying to make an ArcGIS Explorer Add-In for internal use.
What's I wnat to do is to display a shapefile in current display when a user click a button.
I already tried the sample code from SDK help but nothing happens.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using ESRI.ArcGISExplorer;
using ESRI.ArcGISExplorer.Application;
using ESRI.ArcGISExplorer.Mapping;
using ESRI.ArcGISExplorer.Geometry;
using ESRI.ArcGISExplorer.Data;
using ESRI.ArcGISExplorer.Threading;
namespace anakPetak
public class anakPetakButton : ESRI.ArcGISExplorer.Application.Button
public override void OnClick()
//Create a DataSourceProperties object that holds the connection information to the feature class.
DataSourceProperties featureLayerConnectionProps = new DataSourceProperties(@"C:\Korintiga\npa_tanam.shp");
//Create a feature layer.
FeatureLayer anakPetakFeatureLayer = new FeatureLayer(featureLayerConnectionProps);
//Connect the layer to the feature class.
bool connected = anakPetakFeatureLayer.Connect();
//Add the layer to the map.
if (connected)
ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.Map.ChildItems.Add(anakPetakFeatureLayer);
System.Diagnostics.Debug.Print("Test");
else
//Investigate connection issue.
ConnectionStatus status = anakPetakFeatureLayer.ConnectionStatus;
if (status.HasError)
System.Diagnostics.Debug.Print(status.ErrorString);
Would you please give an idea?
Many thanks.
