Need help projecting data....again
738
08-01-2012 09:55 AM
RyanMiller
New Contributor III
I have downloaded a State-wide wetland dataset from the FWS website, clipped it down to the County of interest and now need help with projecting it correctly to line up with our current data.  This seems to happen to me every time so if someone has any good resources on this subject I would appreciate it.
Anyway, I attached the dataset information below of interest (vbc_wetlands2) along with another dataset (County Drains) with the desired projection.  Any suggestions?
Thanks in advance!
Wetland Layer to be re-projected:
Data Type: Shapefile Feature Class
Shapefile: P:\temp\MI_shapefile_wetlands\vbc_wetland2.shp
Geometry Type: Polygon
Projected Coordinate System: NAD_1983_Albers
Projection: Albers
False_Easting: 0.00000000
False_Northing: 0.00000000
Central_Meridian: -96.00000000
Standard_Parallel_1: 29.50000000
Standard_Parallel_2: 45.50000000
Latitude_Of_Origin: 23.00000000
Linear Unit:  Meter
Geographic Coordinate System: GCS_North_American_1983
Datum:  D_North_American_1983
Prime Meridian:  Greenwich
Angular Unit:  Degree
Current dataset of desired projection:
Shapefile: J:\VANBUREN_GEODATABASE\Shapefiles\liaa update\County Drains.shp
Geometry Type: Line
Projected Coordinate System: NAD_1983_StatePlane_Michigan_South_FIPS_2113_Feet
Projection: Lambert_Conformal_Conic
False_Easting: 13123333.33333333
Central_Meridian: -84.36666667
Standard_Parallel_1: 42.10000000
Standard_Parallel_2: 43.66666667
Latitude_Of_Origin: 41.50000000
Linear Unit:  Foot_US
RayChilcote
Transform the data using the Project method:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=project_(data_management)
If any exist, read up and use the best Geographic Transformation method.
