Mark,
How can I set the hyperlinks for a parcels map to open PDF documents when the user clicks the features in ArcGis explorer?
Shany
Hello
I have created a feature class in a geodatabase. and for each feature I defined a hyperlink (eg. C:\xyz\abc.pdf). It works fine in ArcMap. But when I add this to ArcGIS explorer the path is popping up as just a string. Is there something I am missing for the path to show up as hyperlink?
Srikanth
