relate table in ArcGIS Explorer 1700
920
09-09-2011 02:10 PM
sarbajitgurung
Does a feature layer which has a table related to it show up in ArcGIS Explorer? It works in my web mapping application with the attributes of the related table hyperlinked. However, ArcGIS Explorer only shows the attributes of the layer and not the hyperlink of the related table.
Does anyone know how to fix this issue?
Many thanks,
Sarbajit.
HaroldBostic
Occasional Contributor II
Hello, did you find out an answer to this question?
JurajMalega
hey
you can do it programatically...with GetRelatedRows Method
http://help.arcgis.com/en/arcgisexplorer/1500/sdk/componenthelp/index.html#//0003000003wn000000
you can find some examples here..
bye
AriIsaak1
This is great info, but Esri should allow us to enable relates or something
Esri - could you implement this as an out of the box feature on a subsequent build. Often I do work for clients and they want to see the data once it is complete. Without relationship classes I cannot give them the pictures. My clients don't want to purchase ArcGIS Desktop just to see the work I did for them. If File Geodatabases are supported then relationship classes within those file geodatabases should be supported also.
Thank you,
Ari
